Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This machine has been faithfully washing clothes for my family for over 30 years. It will soon be 40 years old!
Be sure to bail out any excess water before disconnecting hoses as shown in video. If your pump is completely failed as mine was, have bucket ready to catch excess water still in tub. The towels mentioned in the video are also highly recommended. Similarly, always be ready to catch water from the supply hoses when they are disconnected as well.
Be sure your water supply cutoff valve(s) are fully shut off before disconnecting. I found a significant amount of trapped water in the drain hose. So I made a temporary plug from a piece of "magic eraser" foam to staunch the flow until I could get the hose outside the house to fully drain it. You could instead drain it at any indoor drain.
Can't believe this pump lasted 39+ years and thousands of washes before failing in April 2019. These pumps run anytime the motor is running too! Either agitating or spinning the inner tub and the pump is running as well.
This motor has 39+ years of service and is still going strong! Try getting this kind of service out of a modern plastic and garbage electronic controls machine.... Good luck!
The machine was vibrating a bit more than usual in the last 3 or 4 months. I tightened the three tub centering springs down about three turns each... Problem solved! These suckers are nearly foolproof and practically indestructible.... like the Toyota Hilux truck made famous on "Top Gear".
If you see someone discarding one of these machines do yourself a favor and ask them if you can have it. All the parts are readily available and working on them is dead simple. Remember the loneliest guy in town comercials ? It was no exaggeration. You can thank me later.
Uma outra pessoa concluiu este guia.
