Ir para o conteúdo principal
Mayflash Arcade Stick F300 Microswitch Replacement
O que você precisa
  1. Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: passo 1, imagem 1 %32 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: passo 1, imagem 2 %32 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: passo 1, imagem 3 %32
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
  2. Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: passo 2, imagem 1 %32 Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: passo 2, imagem 2 %32
    • Remove the four 9 mm truss head screws fastening the clear plastic square joystick gate to the casing underneath using a Phillips #1 screwdriver.
  3. Mayflash Arcade Stick F300 Microswitch Replacement: passo 3, imagem 1 %32 Mayflash Arcade Stick F300 Microswitch Replacement: passo 3, imagem 2 %32 Mayflash Arcade Stick F300 Microswitch Replacement: passo 3, imagem 3 %32
    • Gently push back on each of the four black locking tabs securing the joystick gate to the casing.
    • Remove the joystick gate.
  4. Mayflash Arcade Stick F300 Microswitch Replacement: passo 4, imagem 1 %32 Mayflash Arcade Stick F300 Microswitch Replacement: passo 4, imagem 2 %32
    • Lift the chosen microswitch vertically off the rod holding it in position.
    • Desolder the wire from the terminal (metal connection point).
    • Beware of overheating the soldering kit as it can damage electronic components.
    • Use a wire stripper or small blade to strip the insulation approximately 1 cm from the end of the wire before resoldering to the new part.
Conclusão
Uma outra pessoa concluiu este guia.
Saul Aguiar
Membro desde: 09/05/24
293 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 48
Ao todo: 376
