Ir para o conteúdo principal
Mayflash Arcade Stick F300 Joystick Replacement
O que você precisa
  1. Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: passo 1, imagem 1 %32 Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: passo 1, imagem 2 %32 Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: passo 1, imagem 3 %32
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
  2. Mayflash Arcade Stick F300 Joystick Replacement, Joystick: passo 2, imagem 1 %32 Mayflash Arcade Stick F300 Joystick Replacement, Joystick: passo 2, imagem 2 %32
    • Detach the micro switch cables connected to the PCB (printed circuit board).
  3. Mayflash Arcade Stick F300 Joystick Replacement: passo 3, imagem 1 %32 Mayflash Arcade Stick F300 Joystick Replacement: passo 3, imagem 2 %32 Mayflash Arcade Stick F300 Joystick Replacement: passo 3, imagem 3 %32
    • Use a flathead screwdriver to hold the bottom screw of the joystick lever in place.
    • Flip the device over.
    • Grab the ball top of the joystick and twist while the screwdriver prevents the screw from turning.
    • Once the ball top is removed, slide off the plastic tube and plate from the joystick.
  4. Mayflash Arcade Stick F300 Joystick Replacement: passo 4, imagem 1 %32 Mayflash Arcade Stick F300 Joystick Replacement: passo 4, imagem 2 %32 Mayflash Arcade Stick F300 Joystick Replacement: passo 4, imagem 3 %32
    • Flip the device over again, exposing the inside.
    • Use a Phillips #1 screwdriver to remove the four screws holding down the joystick lever.
    • Slide the joystick out of the outer plastic casing.
Conclusão
Jess Anderson
Membro desde: 09/04/24
342 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 471
