Ir para o conteúdo principal
MaxWest TAB-7360DC Battery Replacement
O que você precisa
  1. MaxWest TAB-7360DC Battery Replacement, Back Hard Case: passo 1, imagem 1 %32 MaxWest TAB-7360DC Battery Replacement, Back Hard Case: passo 1, imagem 2 %32 MaxWest TAB-7360DC Battery Replacement, Back Hard Case: passo 1, imagem 3 %32
    • Insert plastic opening tool at the corner of the screen, in between the back case and the front.
    • Volume buttons will fall out during removal.
    • When opening up the case, have the I/O ports facing you and turn the back case towards the right. There is a short wire connecting the speaker to the logic board.
  2. MaxWest TAB-7360DC Battery Replacement: passo 2, imagem 1 %32 MaxWest TAB-7360DC Battery Replacement: passo 2, imagem 2 %32
    • Carefully pry the tape from the battery, the bottom left chip, and the ribbon cable towards the bottom-right of the board. The bottom left has a little silver square component that must also be unclipped and untaped.
    • The battery is glued to the back of the screen; therefore pull the battery off of the back with caution. There will be resistance but that's okay.
  3. MaxWest TAB-7360DC Battery Replacement: passo 3, imagem 1 %32
    • Gently unclip the data cable retainers and remove the wires from the junctions.
    • Peel the tape off the wire near the bottom of the case.
  4. MaxWest TAB-7360DC Battery Replacement: passo 4, imagem 1 %32
    • Remove the two 4mm screws (circled in orange) with a 00 Phillips head driver.
    • Unclip the black plastic retainer near the data port. The PCB should now be able to be gently pulled off.
  5. MaxWest TAB-7360DC Battery Replacement: passo 5, imagem 1 %32
    • Make contact with the battery terminals with the hot tip of the soldering iron for a few seconds while slowly pulling the wire away.
    • DO NOT TOUCH BOTH THE BLACK AND RED LEADS AT THE SAME TIME WITH THE SOLDERING IRON
Conclusão
Gillian Bundles
Membro desde: 03/21/18
221 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S4-G3, Baechle Spring 2018 Membro de IUPUI, Team S4-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 55
Duração total: 1,592
