Ir para o conteúdo principal
Mavic 2 Main Board Replacement
O que você precisa
  1. Mavic 2 Main Board  Replacement, Remove screws: passo 1, imagem 1 %32
    • Begin to remove screws from belly of drone.
  2. Mavic 2 Main Board  Replacement, Continue to remove screws: passo 2, imagem 1 %32 Mavic 2 Main Board  Replacement, Continue to remove screws: passo 2, imagem 2 %32 Mavic 2 Main Board  Replacement, Continue to remove screws: passo 2, imagem 3 %32
    • remove the rest of the screws
  3. Mavic 2 Main Board  Replacement: passo 3, imagem 1 %32 Mavic 2 Main Board  Replacement: passo 3, imagem 2 %32
    • After all 8 Screws are removed. Remove the back panel. Keep in mind there is a ribbon connecting the panel and the main board. You must detach the ribbon from either side.
  4. Mavic 2 Main Board  Replacement: passo 4, imagem 1 %32
    • Unscrew the screws holding the board in place, as well as all the ribbons and antennas connecting the board to the frame.
  5. Mavic 2 Main Board  Replacement: passo 5, imagem 1 %32
    • Then remove the old board. Replace the new board you have and repeat the process in reverse.
Conclusão
Equipe
Um comentário
Hello sir,
I have a question and I hope to find the answer
The plane (Mavic 2) collided with a pilot turned into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works, the camera shake.
Amr Ahmed - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 35
Ao todo: 1,483
