Ir para o conteúdo principal
Matsunichi MarquisPad MP977 Plastic Front Panel Replacement
O que você precisa
  1. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement, Plastic Front Panel: passo 1, imagem 1 %32
    • Remove the two screws using a PH #00 Phillips head screw driver.
  2. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 2, imagem 1 %32 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 2, imagem 2 %32 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 2, imagem 3 %32
    • Place the device face down on a flat surface.
    • Insert one of the wide tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 3, imagem 1 %32 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 3, imagem 2 %32
    • Insert opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 4, imagem 1 %32
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 5, imagem 1 %32
    • Remove the screws holding the metal frame plate in place.
    • Remove the metal frame plate from the plastic housing.
  6. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 6, imagem 1 %32 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: passo 6, imagem 2 %32
    • Place the metal frame plate and components into the new plastic front panel.
Conclusão
Uma outra pessoa concluiu este guia.
Rachel Servis
Membro desde: 03/24/15
89 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 Membro de UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G1
Membros da 3
Autoria de 6 guias
Um comentário
where can you order the front plastic panel from? and how much?
daf01ca - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 366
