O que você precisa
Using the PH #00 Phillips head screwdriver, unscrew the two screws.
Place the device face down on a flat surface.
Insert the wide-tipped plastic opening tool into the top of the left speaker slot.
Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and the back plate until you reach the power button.
Quase terminado!
Conclusão
