Ir para o conteúdo principal
Matsunichi MarquisPad MP977 Front Facing Camera Replacement
O que você precisa
  1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement, Front Facing Camera: passo 1, imagem 1 %32
    • Using the PH #00 Phillips head screwdriver, unscrew the two screws.
  2. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 2, imagem 1 %32 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 2, imagem 2 %32 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 2, imagem 3 %32
    • Place the device face down on a flat surface.
    • Insert the wide-tipped plastic opening tool into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and the back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 3, imagem 1 %32 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 3, imagem 2 %32
    • Insert the opening tool into the slot located to the right of the speaker, at the top edge of the device.
    • Then, pry open the back plate of the device , and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 4, imagem 1 %32
    • Remove the back plate and place it to the side of the device.
  5. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 5, imagem 1 %32
    • With the same screw driver, PH #00 Phillips head, remove the seven screws holding in the motherboard.
    • Place the screws somewhere safe where they wont fall.
  6. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 6, imagem 1 %32 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 6, imagem 2 %32
    • Gently pull the camera optic fiber out of it's slot to release the flap. This will allow the flap to open easily.
    • Be sure not to damage the camera port.
  7. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 7, imagem 1 %32 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: passo 7, imagem 2 %32
    • Last, Insert the new camera into the pinhole camera slot.
Conclusão
Equipe
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 Membro de UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 240
