Ir para o conteúdo principal
Matsunichi MarquisPad MP977 Battery Replacement
O que você precisa
  1. Matsunichi MarquisPad MP977 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the two screws using a Phillips #00 screwdriver.
  2. Matsunichi MarquisPad MP977 Battery Replacement: passo 2, imagem 1 %32 Matsunichi MarquisPad MP977 Battery Replacement: passo 2, imagem 2 %32 Matsunichi MarquisPad MP977 Battery Replacement: passo 2, imagem 3 %32
    • Place the device face down on a flat surface.
    • Insert one of the wide-tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure to avoid puncturing the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Battery Replacement: passo 3, imagem 1 %32 Matsunichi MarquisPad MP977 Battery Replacement: passo 3, imagem 2 %32
    • Insert the opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counterclockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Battery Replacement: passo 4, imagem 1 %32
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Battery Replacement: passo 5, imagem 1 %32 Matsunichi MarquisPad MP977 Battery Replacement: passo 5, imagem 2 %32
    • Detach the battery from the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Evan Campbell
Membro desde: 03/24/15
88 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 Membro de UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,556
