Ir para o conteúdo principal
Matsunichi M97 9 inch Camera Replacement
O que você precisa
  1. Matsunichi M97 9 inch Camera Replacement, Battery: passo 1, imagem 1 %32
    • Open the micro SD cover located on the back of the device.
  2. Matsunichi M97 9 inch Camera Replacement: passo 2, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the two 4mm screws next to the micro SD port.
  3. Matsunichi M97 9 inch Camera Replacement: passo 3, imagem 1 %32 Matsunichi M97 9 inch Camera Replacement: passo 3, imagem 2 %32 Matsunichi M97 9 inch Camera Replacement: passo 3, imagem 3 %32
    • Use the iFixit opening tool to pry off the back cover of the device.
    • The volume buttons and the lock switch will come loose when the back comes off.
  4. Matsunichi M97 9 inch Camera Replacement: passo 4, imagem 1 %32 Matsunichi M97 9 inch Camera Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to disconnect the battery from the motherboard.
  5. Matsunichi M97 9 inch Camera Replacement: passo 5, imagem 1 %32 Matsunichi M97 9 inch Camera Replacement: passo 5, imagem 2 %32
    • Carefully unstick the battery from the frame using the spudger.
    • Do not bend or puncture the battery during removal.
  6. Matsunichi M97 9 inch Camera Replacement, Motherboard: passo 6, imagem 1 %32 Matsunichi M97 9 inch Camera Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the six 2mm screws that hold the motherboard onto the case using the Phillips #00 screwdriver.
    • Use the same screwdriver to remove the single 4mm screw.
  7. Matsunichi M97 9 inch Camera Replacement: passo 7, imagem 1 %32 Matsunichi M97 9 inch Camera Replacement: passo 7, imagem 2 %32
    • Gently pull the display ribbon cable to unplug it from the motherboard.
  8. Matsunichi M97 9 inch Camera Replacement: passo 8, imagem 1 %32
    • Use a spudger or an iFixit opening tool to lift the locking mechanism holding the camera ribbon cable.
  9. Matsunichi M97 9 inch Camera Replacement: passo 9, imagem 1 %32 Matsunichi M97 9 inch Camera Replacement: passo 9, imagem 2 %32
    • Lift up on the wifi antenna cable to unsnap it from the motherboard.
    • Then unhook the cable from the holding bracket.
  10. Matsunichi M97 9 inch Camera Replacement: passo 10, imagem 1 %32 Matsunichi M97 9 inch Camera Replacement: passo 10, imagem 2 %32
    • Use the spudger or iFixit opening tool to lift up on the locking mechanism for the digitizer ribbon cable.
    • Pull the cable from its connection.
  11. Matsunichi M97 9 inch Camera Replacement: passo 11, imagem 1 %32 Matsunichi M97 9 inch Camera Replacement: passo 11, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the four 4mm screws that hold the speakers in place.
  12. Matsunichi M97 9 inch Camera Replacement: passo 12, imagem 1 %32
    • Pull the vibration motor out of its housing.
  13. Matsunichi M97 9 inch Camera Replacement: passo 13, imagem 1 %32 Matsunichi M97 9 inch Camera Replacement: passo 13, imagem 2 %32
    • Lift the motherboard off the frame.
  14. Matsunichi M97 9 inch Camera Replacement, Camera: passo 14, imagem 1 %32 Matsunichi M97 9 inch Camera Replacement, Camera: passo 14, imagem 2 %32
    • Remove the camera from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 46
