Ir para o conteúdo principal
Matchbox Dino Trapper Trailer Eyes Replacement
O que você precisa
  1. Matchbox Dino Trapper Trailer Eyes Replacement, Eyes: passo 1, imagem 1 %32
    • Open the jaw of the T-Rex to reveal the screw on the roof of its mouth.
  2. Matchbox Dino Trapper Trailer Eyes Replacement: passo 2, imagem 1 %32
    • Using a JIS #1 screwdriver, remove the 9.6mm screw.
  3. Matchbox Dino Trapper Trailer Eyes Replacement: passo 3, imagem 1 %32
    • Using tweezers or wire cutters for tension, remove the cover to reveal the LED assembly.
  4. Matchbox Dino Trapper Trailer Eyes Replacement: passo 4, imagem 1 %32
    • Remove the plastic cover from the top of the LED.
  5. Matchbox Dino Trapper Trailer Eyes Replacement: passo 5, imagem 1 %32
    • Hold the LED to remove slack from the wires, and cut the wires as shown to remove the faulty LED.
Conclusão
To reassemble your device, follow these instructions in reverse order. Use a soldering station to solder new LED onto the fresh-cut wires.
Vincent Crabtree
Membro desde: 03/27/18
267 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G3, Harley Spring 2018 Membro de IUPUI, Team S3-G3, Harley Spring 2018
IUPUI-HARLEY-S18S3G3
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 216
