Ir para o conteúdo principal
MasterCraft Eliminator Waterproof Spotlight Battery Replacement
O que você precisa
  1. MasterCraft Eliminator Waterproof Spotlight Battery Replacement, Battery: passo 1, imagem 1 %32 MasterCraft Eliminator Waterproof Spotlight Battery Replacement, Battery: passo 1, imagem 2 %32
    • Twist the front cover of the spotlight in a counter-clockwise rotation and remove it from the device.
  2. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: passo 2, imagem 1 %32 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: passo 2, imagem 2 %32
    • Remove the rear piece which is the protection cover for the charging port.
  3. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: passo 3, imagem 1 %32 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: passo 3, imagem 2 %32
    • Using the JIS #00 screwdriver, remove the two screws securing the motherboard to the device.
  4. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: passo 4, imagem 1 %32 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: passo 4, imagem 2 %32 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: passo 4, imagem 3 %32
    • Using the JIS #00 screwdriver, remove the single screw securing the charging port and remove the charging port from the device.
  5. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: passo 5, imagem 1 %32 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: passo 5, imagem 2 %32 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: passo 5, imagem 3 %32
    • Carefully disconnect the battery and remove it from the device.
Conclusão
1Comentário do guia
Can you get the 3wledbulb
olddoc55 - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 43
Ao todo: 1,948
