Ir para o conteúdo principal
Martian Victory Watch band Replacement
O que você precisa
  1. Martian Victory Watch band Replacement, Watch band: passo 1, imagem 1 %32
    • Take the watch band removal tool and insert it in the small slit between watch bezel and the band, resting up against the bezel.
  2. Martian Victory Watch band Replacement: passo 2, imagem 1 %32
    • Press down of the shaft that holds the band on, while simultaneously dragging the tip of the tool back towards the band in order to compress the spring bar that holds the band on.
    • Drag the tip of the tool away from the bezel while still pressing down in order to remove the shaft from the bezel.
    • The spring shaft may decompress once its out of the bezel and try to shoot away.
  3. Martian Victory Watch band Replacement: passo 3, imagem 1 %32
    • Repeat these steps on the other side of the band to completely remove the band, ready for cleaning or replacement.
Conclusão
Dominic Coffey
Membro desde: 10/24/16
231 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-3, Baechle Fall 2016 Membro de IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 274
