Ir para o conteúdo principal
Marshall Woburn Tweeter Replacement
O que você precisa
  1. Marshall Woburn Tweeter Replacement, Back Panel: passo 1, imagem 1 %32 Marshall Woburn Tweeter Replacement, Back Panel: passo 1, imagem 2 %32
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn Tweeter Replacement: passo 2, imagem 1 %32 Marshall Woburn Tweeter Replacement: passo 2, imagem 2 %32
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn Tweeter Replacement: passo 3, imagem 1 %32
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshall Woburn Tweeter Replacement, I/O Board: passo 4, imagem 1 %32
    • Disconnect the 5 wires circled in red from the back input board.
    • Grip and pull the connectors, not the wires.
    • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
  5. Marshall Woburn Tweeter Replacement: passo 5, imagem 1 %32 Marshall Woburn Tweeter Replacement: passo 5, imagem 2 %32
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshall Woburn Tweeter Replacement: passo 6, imagem 1 %32
    • Completely remove the I/O board and the attached plate.
  7. Marshall Woburn Tweeter Replacement, Tweeter: passo 7, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the tweeters to the frame.
    • Disconnect the two wires from the back of each tweeter.
  8. Marshall Woburn Tweeter Replacement: passo 8, imagem 1 %32
    • Lift the tweeter from the frame to remove it.
Conclusão
Kenneth
Membro desde: 10/29/23
174 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G4
3 Membros
Autoria de 6 guias
1Comentário do guia
Any ideas to which new tweeters to buy?
Lars - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 48
Ao todo: 892
