Ir para o conteúdo principal
Marshall Woburn I/O Board Replacement
O que você precisa
  1. Marshall Woburn I/O Board Replacement, Back Panel: passo 1, imagem 1 %32 Marshall Woburn I/O Board Replacement, Back Panel: passo 1, imagem 2 %32
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn I/O Board Replacement: passo 2, imagem 1 %32 Marshall Woburn I/O Board Replacement: passo 2, imagem 2 %32
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn I/O Board Replacement: passo 3, imagem 1 %32
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshall Woburn I/O Board Replacement, I/O Board: passo 4, imagem 1 %32
    • Disconnect the 5 wires circled in red from the back input board.
    • There may be a little resistance when pulling on the wires, but it should not require excessive force.
  5. Marshall Woburn I/O Board Replacement: passo 5, imagem 1 %32 Marshall Woburn I/O Board Replacement: passo 5, imagem 2 %32
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshall Woburn I/O Board Replacement: passo 6, imagem 1 %32
    • Completely remove the I/O board and the attached plate.
Conclusão
Ryan Berry
Membro desde: 10/31/23
237 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G4
Membros da 3
Autoria de 6 guias
Um comentário
what is step 7? Replace the board? PS. I was born in N Dartmouth!
Mary F Boston - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 53
Duração total: 361
