Ir para o conteúdo principal
Marshall Kilburn Battery Replacement
O que você precisa
  1. Marshall Kilburn Battery Replacement, Battery: passo 1, imagem 1 %32 Marshall Kilburn Battery Replacement, Battery: passo 1, imagem 2 %32
    • Place the unit face down as shown in the picture, exposing the battery cover.
    • Remove the two 4.0mm long screws holding the cover on using a T10 driver.
  2. Marshall Kilburn Battery Replacement: passo 2, imagem 1 %32
    • Remove the battery cover using a fingernail or nylon spudger.
  3. Marshall Kilburn Battery Replacement: passo 3, imagem 1 %32
    • Remove the battery and unplug the power lead.
Conclusão
3 comentários
Where can I get a replacement battery? The unhelpful guys at Marshall say it’s not a spare part that can be soruced/replaced. Any suggestions?
Guy
Guy - Responder
Hi, does anybody know how to recharge the battery external, because something on the platina fried (LL10) component, and it want charge through the killburn, but works fine with battery. Thank you
Adnan Kasumovic - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 119
Duração total: 7,961
