Ir para o conteúdo principal
Marshall Emberton Motherboard Replacement
O que você precisa
  1. Marshall Emberton Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • In order to start uncrewing any of the screws off the speaker we have to peel the protective cover off.
  2. Marshall Emberton Motherboard Replacement: passo 2, imagem 1 %32
    • Pry the front of the speaker off using your nails or a device capable of fitting inside the crevice.
  3. Marshall Emberton Motherboard Replacement: passo 3, imagem 1 %32
    • Once pried off, we have to remove the eight 1.2 cm screws on the speaker.
    • Use a TR9 screwdriver for the screws.
  4. Marshall Emberton Motherboard Replacement: passo 4, imagem 1 %32
    • There are six more 1.2cm screws required to remove in order to take out the motherboard.
  5. Marshall Emberton Motherboard Replacement: passo 5, imagem 1 %32 Marshall Emberton Motherboard Replacement: passo 5, imagem 2 %32
    • You then need to unplug all three wires connected to the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Asia Baldwin
Membro desde: 09/26/22
697 Reputação
Autoria de 5 guias
Equipe
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Membro de CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
Membros da 5
Autoria de 5 guias
Um comentário
How or where can I purchase a new motherboard for my Emberton II? My won’t charge the battery any longer, I’ve since bought another speaker but would like to repair this one if I can get my hands on a new motherboard. Thanks in advance.
jeremy a bolduc - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 67
Duração total: 915
