Ir para o conteúdo principal
Marshall Emberton Main Speaker Replacement
O que você precisa
  1. Marshall Emberton Main Speaker Replacement, Main Speaker: passo 1, imagem 1 %32
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Main Speaker Replacement: passo 2, imagem 1 %32
    • Pry the front of the speaker that says "Marshall" in order to get inside the speaker.
  3. Marshall Emberton Main Speaker Replacement: passo 3, imagem 1 %32
    • Remove the eight 1.2 cm screws using a TR9 screwdriver.
  4. Marshall Emberton Main Speaker Replacement: passo 4, imagem 1 %32
    • Now pop the speaker out and remove the entire piece.
  5. Marshall Emberton Main Speaker Replacement: passo 5, imagem 1 %32
    • Now you must disconnect two wire connectors, by firmly tugging on the wires.
    • The new speakers can now be connected and put back together.
Conclusão
Asia Baldwin
Membro desde: 09/26/22
697 Reputação
Autoria de 5 guias
Equipe
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Membro de CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
Membros da 5
Autoria de 5 guias
Um comentário
Hi! Where from can I by the speakers? pls help
Cristian MUNTEANU - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 137
Duração total: 2,606
