Ir para o conteúdo principal
Marshall Emberton Button Replacement
O que você precisa
  1. Marshall Emberton Button Replacement, Button: passo 1, imagem 1 %32
    • Remove the rubber casing from the speaker by peeling it off using your nails.
    Pergunte ao FixBot
    Comentar
  2. Marshall Emberton Button Replacement: passo 2, imagem 1 %32
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Marshall Emberton Button Replacement: passo 3, imagem 1 %32
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
    Pergunte ao FixBot
    Comentar
  4. Marshall Emberton Button Replacement: passo 4, imagem 1 %32
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
    Pergunte ao FixBot
    Comentar
  5. Marshall Emberton Button Replacement: passo 5, imagem 1 %32
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Asia Baldwin
Membro desde: 09/26/22
781 Reputação
Autoria de 5 guias
Equipe
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Membro de CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 Membros
Autoria de 6 guias
4Comentários do guia
where can i find a replacement button
MANU 1907 - Responder Compartilhar
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - Responder Compartilhar
yes, i confirme !!!
Mallet Jp - Responder Compartilhar
@cooleo fortunately i figured it out but yeah you ned to disassemble multiple parts. disassemble from the front panel (marshal logo panel is pressure fit, undo the phillips, and take the board out behind it, and then take out the top out + switch.
Daniel Hyunsu Kim - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 37
Últimos 30 dias: 193
Ao todo: 4,162
