Ir para o conteúdo principal
Marshall Emberton Battery Replacement
O que você precisa
  1. Marshall Emberton Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the rubber casing from the speaker using your nails to peel the cover off.
  2. Marshall Emberton Battery Replacement: passo 2, imagem 1 %32
    • Pry out both covers that are on the front and backside of the speaker to reveal the screws to get inside the speaker.
  3. Marshall Emberton Battery Replacement: passo 3, imagem 1 %32 Marshall Emberton Battery Replacement: passo 3, imagem 2 %32
    • Use a TR9 screwdriver to remove the eight 1.2 cm screws.
    • Use a spudger or opening tool to pry out the speakers.
  4. Marshall Emberton Battery Replacement: passo 4, imagem 1 %32
    • Use a TR9 screwdriver to remove the six 1 cm screws that secure the motherboard.
  5. Marshall Emberton Battery Replacement: passo 5, imagem 1 %32 Marshall Emberton Battery Replacement: passo 5, imagem 2 %32
    • Disconnect the three wire connectors marked, by firmly tugging on the wire.
  6. Marshall Emberton Battery Replacement: passo 6, imagem 1 %32
    • Use TR9 screwdriver to remove the final two 1.2 cm screws that secure the battery.
Conclusão
5 outras pessoas executaram este guia.
Asia Baldwin
Membro desde: 09/26/22
781 Reputação
Autoria de 5 guias
Equipe
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Membro de CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 Membros
Autoria de 6 guias
5Comentários do guia
Add any tools at the top you used in this repair guide and also any replacement parts if you can.
Yamilena Hernandez - Responder Compartilhar
How can i buy battery
Rubel hussain - Responder Compartilhar
How can I buy the battery
Sreenath Ps - Responder Compartilhar
How to buy a battery for my emberton?
MADHANRAJ MURUGESAN - Responder Compartilhar
From where to buy battery? What is the battery specification?
Hasin Shahriar - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 21
Últimos 7 dias: 125
Últimos 30 dias: 447
Ao todo: 18,966
