O que você precisa
The additional sensor with the joint and the heat shrink tubing is available as a replacement kit on www.marco.it .
Kits are only available as a registered user, and can be seen for each pump in their dedicated tab on the page.
Use the pliers to cut the red and black cables before and after the joint.
Use the joint as a reference on how much you need to remove.
Use the cutting plier or (if you have it) the stripping plier to remove the sheath.
Start on the motor side, and press the metal joint on the cable.
Proceed with by inserting the other end, the short cable coming from the sensor.
Repeat the process also for the other cable.
Fix the cables using the plastic strap.
Cut the excess of the plastic strap using the cutting pliers.
