Ir para o conteúdo principal
Marco TA1 Gas Bottle Replacement
O que você precisa
  1. Marco TA1 Gas Bottle Replacement, Let's get ready: passo 1, imagem 1 %32
    • You need your TA1 handheld horn and a spare gas bottle to proceed.
  2. Marco TA1 Gas Bottle Replacement, Remove the trumpet from the gas bottle: passo 2, imagem 1 %32 Marco TA1 Gas Bottle Replacement, Remove the trumpet from the gas bottle: passo 2, imagem 2 %32 Marco TA1 Gas Bottle Replacement, Remove the trumpet from the gas bottle: passo 2, imagem 3 %32
    • Press down the flap.
    • Be careful: if you press too much it may break.
  3. Marco TA1 Gas Bottle Replacement, Push the half-circle lock: passo 3, imagem 1 %32 Marco TA1 Gas Bottle Replacement, Push the half-circle lock: passo 3, imagem 2 %32 Marco TA1 Gas Bottle Replacement, Push the half-circle lock: passo 3, imagem 3 %32
    • While pressing the flap, move the half-circle lock to free the trumpet from the tank.
  4. Marco TA1 Gas Bottle Replacement, Remove the trumpet from the bottle: passo 4, imagem 1 %32 Marco TA1 Gas Bottle Replacement, Remove the trumpet from the bottle: passo 4, imagem 2 %32
    • You don't need the empty tank anymore. Dispose it like required from your local laws.
  5. Marco TA1 Gas Bottle Replacement, Take the new gas bottle: passo 5, imagem 1 %32
    • Take the new bottle and remove the cap.
  6. Marco TA1 Gas Bottle Replacement, Open the lock: passo 6, imagem 1 %32 Marco TA1 Gas Bottle Replacement, Open the lock: passo 6, imagem 2 %32
    • Open the lock on the trumpet.
  7. Marco TA1 Gas Bottle Replacement, Put the trumpet on the bottle: passo 7, imagem 1 %32 Marco TA1 Gas Bottle Replacement, Put the trumpet on the bottle: passo 7, imagem 2 %32
    • Put the trumpet on the bottle.
    • BE CAREFUL. Keep your fingers away from the trumpet and red circled moving parts: when the trumpet is on the gas bottle and you press it, it will honk!!
  8. Marco TA1 Gas Bottle Replacement, Close the lock on the bottle: passo 8, imagem 1 %32 Marco TA1 Gas Bottle Replacement, Close the lock on the bottle: passo 8, imagem 2 %32
    • BE CAREFUL. The horn may honk if you press it too strong on the red marked part.
  9. Marco TA1 Gas Bottle Replacement, Check that the lock it's completely sealed: passo 9, imagem 1 %32 Marco TA1 Gas Bottle Replacement, Check that the lock it's completely sealed: passo 9, imagem 2 %32
    • The red circled lock has to be like in the picture, out and up. If it's still inside, the trumpet may disconnect.
    • The blue circled part should be like in the picture, with no space between the components.
  10. Marco TA1 Gas Bottle Replacement, You've finished!: passo 10, imagem 1 %32
    • Your gas horn it's now up and running, ready to be used again!
Conclusão
There's no limit on the number of times you change the gas bottle.
Uma outra pessoa concluiu este guia.
Marco Spa
Membro desde: 12/04/15
1.531 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 320
