Introdução
In this guide we will show you how to access the keyboard.
Peças
Nenhum componente especificado.
Grab the back of the calculator with one hand and the cover with the other.
Pull the cover off from one of the sides for easy removal.
"Locking Tab"
To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
Then with the front of the calculator facing down, pull up on the back cover.
The calculator should now be orientated with the front facing down, as shown in picture 2.
Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
Now simply remove the battery.
Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
Here we will use the front panel, separate from the motherboard
Remove the rubber contact lying on top of the keys.
When placing the keys back into the faceplate you have to make sure that they are going in the right direction.
You can tell which way is up by a semicircular extrusion on the back of a key.
The gray and blue keys have the extrusion on the upper left hole looking at the back of the key.
The black keys on the other hand have the extrusions on the lower left hole looking at the back of the key.
