Ir para o conteúdo principal
Makita XPH01 LED Light Replacement
O que você precisa
  1. Makita XPH01 LED Light Replacement, Battery: passo 1, imagem 1 %32
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 LED Light Replacement: passo 2, imagem 1 %32
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 LED Light Replacement: passo 3, imagem 1 %32
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 LED Light Replacement, Outer Casing: passo 4, imagem 1 %32 Makita XPH01 LED Light Replacement, Outer Casing: passo 4, imagem 2 %32
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 LED Light Replacement: passo 5, imagem 1 %32
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 LED Light Replacement: passo 6, imagem 1 %32 Makita XPH01 LED Light Replacement: passo 6, imagem 2 %32
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 LED Light Replacement: passo 7, imagem 1 %32 Makita XPH01 LED Light Replacement: passo 7, imagem 2 %32
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 LED Light Replacement, LED Light: passo 8, imagem 1 %32 Makita XPH01 LED Light Replacement, LED Light: passo 8, imagem 2 %32
    • Use the pointed end of a plastic spudger to push the LED out of the drill.
  9. Makita XPH01 LED Light Replacement: passo 9, imagem 1 %32 Makita XPH01 LED Light Replacement: passo 9, imagem 2 %32
    • Use the pointed edge of a spudger to pull out the black and white wires located on the left hand side of the drill.
    • Use the pointed edge of a spudger to pull out the plastic connector.
  10. Makita XPH01 LED Light Replacement: passo 10, imagem 1 %32 Makita XPH01 LED Light Replacement: passo 10, imagem 2 %32 Makita XPH01 LED Light Replacement: passo 10, imagem 3 %32
    • Use the flat end of the spudger to push in the clip on the plastic connector.
    • Pull both sides of the plastic connector apart.
  11. Makita XPH01 LED Light Replacement: passo 11, imagem 1 %32 Makita XPH01 LED Light Replacement: passo 11, imagem 2 %32 Makita XPH01 LED Light Replacement: passo 11, imagem 3 %32
    • Pull the silver metal clip on the motor away from the drill.
  12. Makita XPH01 LED Light Replacement: passo 12, imagem 1 %32
    • Pull the black trigger assembly away from the drill.
  13. Makita XPH01 LED Light Replacement: passo 13, imagem 1 %32 Makita XPH01 LED Light Replacement: passo 13, imagem 2 %32
    • Use tweezers to pull out the LED light assembly.
    very nice tutorial !
    King Rump - Responder
Conclusão
Eric Herwatt
Membro desde: 10/05/16
984 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 15-4, Livingston Fall 2016 Membro de Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
Membros da 4
Autoria de 7 guias
Um comentário
Should I do these steps if my drill is under a warranty?
Richard Williams - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 30
Duração total: 2,450
