Ir para o conteúdo principal
Makita XPH01 Drill Brush Replacement
O que você precisa
  1. Makita XPH01 Drill Brush Replacement, Battery: passo 1, imagem 1 %32
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Drill Brush Replacement: passo 2, imagem 1 %32
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Drill Brush Replacement: passo 3, imagem 1 %32
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Drill Brush Replacement, Drill Brush: passo 4, imagem 1 %32
    • Hold the drill upright with the back panel facing you.
  5. Makita XPH01 Drill Brush Replacement: passo 5, imagem 1 %32 Makita XPH01 Drill Brush Replacement: passo 5, imagem 2 %32
    • Unscrew two 18mm screws from the back panel with the Phillips PH2 screwdriver.
  6. Makita XPH01 Drill Brush Replacement: passo 6, imagem 1 %32 Makita XPH01 Drill Brush Replacement: passo 6, imagem 2 %32
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  7. Makita XPH01 Drill Brush Replacement: passo 7, imagem 1 %32 Makita XPH01 Drill Brush Replacement: passo 7, imagem 2 %32 Makita XPH01 Drill Brush Replacement: passo 7, imagem 3 %32
    • Hold the drill so the back end is facing toward you.
    • Use the spudger to lift the spring clip out of the back notch.
    • Pull the spring clip forward and rest it in the front notch.
  8. Makita XPH01 Drill Brush Replacement: passo 8, imagem 1 %32 Makita XPH01 Drill Brush Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to pull the drill brush away from the sleeve.
  9. Makita XPH01 Drill Brush Replacement: passo 9, imagem 1 %32 Makita XPH01 Drill Brush Replacement: passo 9, imagem 2 %32 Makita XPH01 Drill Brush Replacement: passo 9, imagem 3 %32
    • Use the plastic opening tool to release the clip connected to the drill brush.
    • Separate the drill brush away from the clip.
Conclusão
3 outras pessoas executaram este guia.
Eric Herwatt
Membro desde: 10/05/16
984 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 15-4, Livingston Fall 2016 Membro de Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
Membros da 4
Autoria de 7 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 35
Duração total: 5,853
