Ir para o conteúdo principal
Makita GA4030K Armature Replacement
O que você precisa
  1. Makita GA4030K Armature Replacement, Disk Cover: passo 1, imagem 1 %32
    • Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
  2. Makita GA4030K Armature Replacement: passo 2, imagem 1 %32
    • Unscrew the handle unit until it is removed completely.
  3. Makita GA4030K Armature Replacement: passo 3, imagem 1 %32 Makita GA4030K Armature Replacement: passo 3, imagem 2 %32
    • Hold the black switch located on the front casing.
    • Still holding the switch, use the lock nut wrench to loosen the silver disk holding everything in place.
    • Once loose, remove the silver disk and/or your grinding disk.
  4. Makita GA4030K Armature Replacement: passo 4, imagem 1 %32 Makita GA4030K Armature Replacement: passo 4, imagem 2 %32
    • Use a Phillips #02 screwdriver to remove the 15 mm pan head screw that holds the cover in place.
    • Remove the cover by lining up the knob on the cover with the notch in face plate.
  5. Makita GA4030K Armature Replacement, Back Cover: passo 5, imagem 1 %32 Makita GA4030K Armature Replacement, Back Cover: passo 5, imagem 2 %32
    • Unscrew the 20 mm tapping screw using a Philips #02 screwdriver.
  6. Makita GA4030K Armature Replacement: passo 6, imagem 1 %32
    • Slide the back cover down the power cable.
  7. Makita GA4030K Armature Replacement, Armature: passo 7, imagem 1 %32 Makita GA4030K Armature Replacement, Armature: passo 7, imagem 2 %32
    • Use a spudger to gently move the brush holder coil to the side.
    • There are two brushes that are secured by two separate brush holders, one on each side.
  8. Makita GA4030K Armature Replacement: passo 8, imagem 1 %32 Makita GA4030K Armature Replacement: passo 8, imagem 2 %32
    • Using a metal spudger, remove both carbon brushes (one on each side) by their copper cabling.
  9. Makita GA4030K Armature Replacement: passo 9, imagem 1 %32 Makita GA4030K Armature Replacement: passo 9, imagem 2 %32 Makita GA4030K Armature Replacement: passo 9, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove the four 20 mm tapping screws that hold the armature assembly in place.
    • Remove the armature assembly
  10. Makita GA4030K Armature Replacement: passo 10, imagem 1 %32 Makita GA4030K Armature Replacement: passo 10, imagem 2 %32
    • Unscrew the four 10 mm tapping screws holding the faceplate using a Phillips #02 screwdriver.
    • Remove the faceplate.
  11. Makita GA4030K Armature Replacement: passo 11, imagem 1 %32 Makita GA4030K Armature Replacement: passo 11, imagem 2 %32
    • Hold the highlighted nut with a size 10 wrench. Unscrew by turning the armature and holding the nut in place.
    • The nut may be difficult to remove.
  12. Makita GA4030K Armature Replacement: passo 12, imagem 1 %32
    • Remove the armature.
Conclusão
5 outras pessoas executaram este guia.
Laura Ann Jagels
Membro desde: 04/01/15
490 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-5, Lancaster Spring 2015 Membro de Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 3,554
