Ir para o conteúdo principal
Maisto Rock Crawler Remote Circuit Board Replacement
O que você precisa
  1. Maisto Rock Crawler Remote Circuit Board Replacement, Remote Circuit Board: passo 1, imagem 1 %32
    • Remove the batteries before doing anything.
    • Use the driver and bit J1 to remove the five 9.5mm Philips screws holding the remote together.
  2. Maisto Rock Crawler Remote Circuit Board Replacement: passo 2, imagem 1 %32
    • Take off the half of the remote that had the screw heads facing up.
  3. Maisto Rock Crawler Remote Circuit Board Replacement: passo 3, imagem 1 %32
    • Slide out the circuit board.
    • Use the soldering iron to desolder the 3 wires.
Conclusão
5 outras pessoas executaram este guia.
kevin
Membro desde: 02/10/16
874 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 1-2, Sullivan Spring 2016 Membro de USF Tampa, Team 1-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G2
Membros da 3
Autoria de 6 guias
5 comentários
Can you show the wheel controller mechanism. I can see 3 contacts on mine but I think mine is missing something that would bring the contacts together as you turn the wheel to steer left and right. Thanks.
Ferdinand Fong - Responder
the triger is broken to drive the truck
joey heller - Responder
Somebody have the remote control for
Theodore Brock - Responder
I have a 1970 R/T charger RC car, 2.4GHz, I changed it up fully, but the pairing light wont come on. But I can show the lights,the control power is good.what is wrong can anybody help me find the problem and fix it.
Keith Pryor - Responder
How to pair new controller ?
Karel Říha - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Duração total: 4,641
