Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Using a Philips screwdriver, remove the two screws on the top of the device, towards the back.
    • Using a Philips screwdriver, remove the two screws on the top of the device, towards the back.
  2. Remove the plastic cover by pulling up on the back and away from the faceplate. Remove the plastic cover by pulling up on the back and away from the faceplate.
    • Remove the plastic cover by pulling up on the back and away from the faceplate.
  3. Remove the faceplate by unclipping the latches on the bottom of the device. Once it's unlatched, pull the faceplate off. Once it's unlatched, pull the faceplate off.
    • Remove the faceplate by unclipping the latches on the bottom of the device.
    • Once it's unlatched, pull the faceplate off.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  5. Using your philips screwdriver, remove the two screws at the base of the disc drive. (See image) Using your philips screwdriver, remove the two screws at the base of the disc drive. (See image)
    • Using your philips screwdriver, remove the two screws at the base of the disc drive. (See image)
  6. Remove the two screws on either side of the silver security bar. Remove the two screws on either side of the silver security bar.
    • Remove the two screws on either side of the silver security bar.
  7. Remove the silver security bar and set aside. Remove the silver security bar and set aside.
    • Remove the silver security bar and set aside.
  8. Remove the two screws on either side of the green circuit-board as seen in the photos.  Once the screws are removed, gently lift the board so you can remove the disc drive.  BE CAREFUL! The board is still attached to the base of the DVD player.  You just need to lift it enough to pull the disc drive out. Remove the two screws on either side of the green circuit-board as seen in the photos.  Once the screws are removed, gently lift the board so you can remove the disc drive.  BE CAREFUL! The board is still attached to the base of the DVD player.  You just need to lift it enough to pull the disc drive out. Remove the two screws on either side of the green circuit-board as seen in the photos.  Once the screws are removed, gently lift the board so you can remove the disc drive.  BE CAREFUL! The board is still attached to the base of the DVD player.  You just need to lift it enough to pull the disc drive out.
    • Remove the two screws on either side of the green circuit-board as seen in the photos. Once the screws are removed, gently lift the board so you can remove the disc drive. BE CAREFUL! The board is still attached to the base of the DVD player. You just need to lift it enough to pull the disc drive out.
  9. Remove the two screws at the back of the disc drive. Remove the two screws at the back of the disc drive. Remove the two screws at the back of the disc drive.
    • Remove the two screws at the back of the disc drive.
  10. You can now gently lift the disc drive out of the the DVD player.  BE CAREFUL! The disc drive is still attached but you are now able to get to underneath it for cleaning and maintenance. You can now gently lift the disc drive out of the the DVD player.  BE CAREFUL! The disc drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
    • You can now gently lift the disc drive out of the the DVD player. BE CAREFUL! The disc drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
Conclusão
Taryn
Membro desde: 15-09-2011
103 reputação
4 Guias de autoria
Equipe
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Todo: 1,249
