Ir para o conteúdo principal
Magic Bullet NutriBullet Base Replacement
O que você precisa
  1. Magic Bullet NutriBullet Base Replacement, Base: passo 1, imagem 1 %32
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Base Replacement: passo 2, imagem 1 %32 Magic Bullet NutriBullet Base Replacement: passo 2, imagem 2 %32
    • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
  3. Magic Bullet NutriBullet Base Replacement: passo 3, imagem 1 %32
    • Once the screws are removed, use slight tension to pull the plastic base up.
    • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
    ensuite comment défaire le reste
    eliette campeau - Responder
Conclusão
Angela Wong
Membro desde: 01/22/15
1.090 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 19-8, Maness Winter 2015 Membro de Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
Membros da 4
Autoria de 10 guias
3 comentários
So far it was easy! Yeah!
Elaine - Responder
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Tommy Simpson - Responder
Where can you buy the base to replace?
Anne-Christine von Wetter - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 42
Duração total: 9,503
