Introdução
If you notice any sharp, moving components outside of your NutriBullet base, then use this replacement guide to learn how to remove and replace the base.
O que você precisa
Once the screws are removed, use slight tension to pull the plastic base up.
3 comentários
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Where can you buy the base to replace?
