Ir para o conteúdo principal
Magic Bullet NutriBullet Base Replacement
O que você precisa
  1. Magic Bullet NutriBullet Base Replacement, Base: passo 1, imagem 1 %32
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Base Replacement: passo 2, imagem 1 %32 Magic Bullet NutriBullet Base Replacement: passo 2, imagem 2 %32
    • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
  3. Magic Bullet NutriBullet Base Replacement: passo 3, imagem 1 %32
    • Once the screws are removed, use slight tension to pull the plastic base up.
    • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
Conclusão
3 outras pessoas executaram este guia.
Angela Wong
Membro desde: 01/22/15
1.156 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 19-8, Maness Winter 2015 Membro de Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Membros
Autoria de 13 guias
3Comentários do guia
So far it was easy! Yeah!
Elaine - Responder
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Tommy Simpson - Responder
Where can you buy the base to replace?
Anne-Christine von Wetter - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 37
Ao todo: 10,393
