Ir para o conteúdo principal
Magic Bullet MB1001B Power Cord Replacement
O que você precisa
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: passo 1, imagem 1 %32
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  2. Magic Bullet MB1001B Power Cord Replacement: passo 2, imagem 1 %32
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  3. Magic Bullet MB1001B Power Cord Replacement: passo 3, imagem 1 %32
    • Remove the black base plate.
  4. Magic Bullet MB1001B Power Cord Replacement: passo 4, imagem 1 %32
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  5. Magic Bullet MB1001B Power Cord Replacement: passo 5, imagem 1 %32
    • Remove the white plastic cable guide.
  6. Magic Bullet MB1001B Power Cord Replacement: passo 6, imagem 1 %32
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
  7. Magic Bullet MB1001B Power Cord Replacement: passo 7, imagem 1 %32
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
Conclusão
Bridget Carr
Membro desde: 10/06/15
266 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-13, Maness Fall 2015 Membro de Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Membros
Autoria de 8 guias
2Comentários do guia
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - Responder
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 2,715
