Ir para o conteúdo principal
Magic Bullet MB1001B Base Gear Replacement
O que você precisa
  1. Magic Bullet MB1001B Base Gear Replacement, Base Gear: passo 1, imagem 1 %32 Magic Bullet MB1001B Base Gear Replacement, Base Gear: passo 1, imagem 2 %32 Magic Bullet MB1001B Base Gear Replacement, Base Gear: passo 1, imagem 3 %32
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
Conclusão
9 outras pessoas executaram este guia.
Jackson Wiley
Membro desde: 10/06/15
333 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-13, Maness Fall 2015 Membro de Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Membros
Autoria de 8 guias
8Comentários do guia
I am sure a black plastic piece that held the blades tight has broken off. I found pieces of it. How do I replace that piece and where can I get it? Everything is working fine, the motor is turning. The blade is too loose to stay in place while engaged.
cheryl ockrant - Responder
Mine did while I was using it, looking for the same answer, I don't want to go out and buy a whole new set
Sheila Angeletti - Responder
It can't be that both my sets of blades are bent. Should the clear plastic piece in the turn by hand?
sleepyhobbit - Responder
Mine is on but the motor is working but the blades aren't spinning
Shenieza Singh - Responder
Glued too hard. The old industrial revolution greed trick of having critical parts made of plastic to interface with metal. Programmed obsolescence. Garbage once broken. This guide should be rated difficult.
Chris J - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 55
Ao todo: 21,575
