Ir para o conteúdo principal
Magellan Roadmate 9055-LM Back Panel Disassembly
O que você precisa
  1. Magellan Roadmate 9055-LM Back Panel Disassembly, Magellan Roadmate 9055-LM Back Panel Disassembly: passo 1, imagem 1 %32
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Back Panel Disassembly: passo 2, imagem 1 %32 Magellan Roadmate 9055-LM Back Panel Disassembly: passo 2, imagem 2 %32 Magellan Roadmate 9055-LM Back Panel Disassembly: passo 2, imagem 3 %32
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Back Panel Disassembly: passo 3, imagem 1 %32 Magellan Roadmate 9055-LM Back Panel Disassembly: passo 3, imagem 2 %32
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Back Panel Disassembly: passo 4, imagem 1 %32 Magellan Roadmate 9055-LM Back Panel Disassembly: passo 4, imagem 2 %32
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Back Panel Disassembly: passo 5, imagem 1 %32
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Back Panel Disassembly: passo 6, imagem 1 %32 Magellan Roadmate 9055-LM Back Panel Disassembly: passo 6, imagem 2 %32 Magellan Roadmate 9055-LM Back Panel Disassembly: passo 6, imagem 3 %32
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Back Panel Disassembly: passo 7, imagem 1 %32 Magellan Roadmate 9055-LM Back Panel Disassembly: passo 7, imagem 2 %32 Magellan Roadmate 9055-LM Back Panel Disassembly: passo 7, imagem 3 %32
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Back Panel Disassembly: passo 8, imagem 1 %32
    • Place the back panel gently on the table.
Conclusão
YuChe Chang
Membro desde: 10/18/16
202 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-5, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-5, Catania Fall 2016
UMASSD-CATANIA-F16S1G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 207
