Ir para o conteúdo principal
Magellan RoadMate 5250T-LM Screen Replacement
O que você precisa
  1. Magellan RoadMate 5250T-LM Screen Replacement, Screen: passo 1, imagem 1 %32 Magellan RoadMate 5250T-LM Screen Replacement, Screen: passo 1, imagem 2 %32
    • Holding the device in place, remove all four 5 mm screws from the back of the device using a Philips Head #000 screwdriver.
    • Place screws aside. Make sure they are easily accessible for reassembling the device.
  2. Magellan RoadMate 5250T-LM Screen Replacement: passo 2, imagem 1 %32 Magellan RoadMate 5250T-LM Screen Replacement: passo 2, imagem 2 %32
    • Lift the back cover using a spudger.
    • Remove back cover slowly and carefully to prevent damage.
  3. Magellan RoadMate 5250T-LM Screen Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Peel back the tape securing the display connector to the motherboard.
    • To ensure proper reassembly, do not remove or fold edges of tape.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Screen Replacement: passo 4, imagem 1 %32 Magellan RoadMate 5250T-LM Screen Replacement: passo 4, imagem 2 %32
    • Undo the four clamps holding down the display.
    • Remove the display from the front cover.
Conclusão
Jaimee Mound
Membro desde: 01/31/16
101 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 345
