Ir para o conteúdo principal
Magellan RoadMate 5236T-LM Display Screen Replacement
O que você precisa
  1. Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: passo 1, imagem 1 %32 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: passo 1, imagem 2 %32 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: passo 1, imagem 3 %32
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Display Screen Replacement: passo 2, imagem 1 %32 Magellan RoadMate 5236T-LM Display Screen Replacement: passo 2, imagem 2 %32 Magellan RoadMate 5236T-LM Display Screen Replacement: passo 2, imagem 3 %32
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Display Screen Replacement: passo 3, imagem 1 %32 Magellan RoadMate 5236T-LM Display Screen Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: passo 4, imagem 1 %32 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: passo 4, imagem 2 %32 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: passo 4, imagem 3 %32
    • Place the front panel on a flat surface, screen side down.
    • Using a plastic opening tool, apply light lifting pressure to each of the 6 casing clips to release the screen from the plastic casing.
Conclusão
Megan Scribner
Membro desde: 10/18/16
324 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-7, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-7, Catania Fall 2016
UMASSD-CATANIA-F16S4G7
3 Membros
Autoria de 5 guias
1Comentário do guia
This would have been even a GREATER POST if, would have included the part number for the replacement screen,
But,
Just good information as to how to remove the damaged screen.
1975PINTOBOBSTER
1975PINTOBOBSTER - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 693
