Ir para o conteúdo principal
Magellan RoadMate 5120-LMTX Battery Replacement
O que você precisa
  1. Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: passo 1, imagem 1 %32 Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: passo 1, imagem 2 %32 Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Battery Replacement: passo 2, imagem 1 %32 Magellan RoadMate 5120-LMTX Battery Replacement: passo 2, imagem 2 %32 Magellan RoadMate 5120-LMTX Battery Replacement: passo 2, imagem 3 %32
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Battery Replacement, Battery: passo 3, imagem 1 %32 Magellan RoadMate 5120-LMTX Battery Replacement, Battery: passo 3, imagem 2 %32
    • Run the tip of a spudger between the battery and the housing to loosen the double-sided tape holding the battery in.
    • Still using the spudger tool, pry the battery from the housing.
    • If you damage the tape while trying to remove the battery, you can replace it with any double-sided tape.
  4. Magellan RoadMate 5120-LMTX Battery Replacement: passo 4, imagem 1 %32 Magellan RoadMate 5120-LMTX Battery Replacement: passo 4, imagem 2 %32 Magellan RoadMate 5120-LMTX Battery Replacement: passo 4, imagem 3 %32
    • Pull the edge of the tape up to remove the tape that holds the battery wire to the motherboard.
    • There is a clear rectangular adhesive strip that also needs to be removed with the pointy end of a spudger.
    • Slowly pull the connection from the motherboard.
    • Do not pull too hard or you will risk damaging the wires.
Conclusão
Steven Prout
Membro desde: 10/08/16
231 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 4-4, Wilson Fall 2016 Membro de IUPUI, Team 4-4, Wilson Fall 2016
IUPUI-WILSON-F16S4G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 481
