Ir para o conteúdo principal
Magellan RoadMate 1440 Power Switch Replacement
O que você precisa
  1. Magellan RoadMate 1440 Power Switch Replacement, Magellan RoadMate 1440 Back Cover Disassembly: passo 1, imagem 1 %32
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Power Switch Replacement: passo 2, imagem 1 %32 Magellan RoadMate 1440 Power Switch Replacement: passo 2, imagem 2 %32
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Power Switch Replacement: passo 3, imagem 1 %32 Magellan RoadMate 1440 Power Switch Replacement: passo 3, imagem 2 %32
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Power Switch Replacement: passo 4, imagem 1 %32 Magellan RoadMate 1440 Power Switch Replacement: passo 4, imagem 2 %32 Magellan RoadMate 1440 Power Switch Replacement: passo 4, imagem 3 %32
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Power Switch Replacement: passo 5, imagem 1 %32 Magellan RoadMate 1440 Power Switch Replacement: passo 5, imagem 2 %32 Magellan RoadMate 1440 Power Switch Replacement: passo 5, imagem 3 %32
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Power Switch Replacement, Power Switch: passo 6, imagem 1 %32
    • Once the back cover has been removed, lift the power switch from the device.
    • This is only a sliding switch, the button to power the device on is inside the unit
Conclusão
Jeremy Johnson
Membro desde: 03/21/16
201 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 7-3, Benson Spring 2016 Membro de Clemson, Team 7-3, Benson Spring 2016
CLEM-BENSON-S16S7G3
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 196
