Introdução
The speaker can be easily removed from the back cover.
O que você precisa
Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
Once you pull off the back cover, remove the orange piece of tape on the speaker.
Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing.
Quase terminado!
Conclusão
