Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will outline how to replace a Magellan RoadMate 1200 motherboard. This piece is an integral part to the system, and may malfunction or break after a long period of use.
Peças
Nenhum componente especificado.
  1. Remove the four rubber caps from the back by using the Phillips #00 screwdriver. Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Kit de ferramentas básico para eletrônica
    Kit pequeno. Grandes possibilidades.
    Shop Toolkits
    Kit de ferramentas
    básico para
    eletrônica
    Shop Toolkits
  4. Remove the back cover from the device by separating the back cover along its seam. Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  5. Pull the speaker cord, horizontally, by its base, away from the motherboard. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  6. Remove the two screws on that are located on opposite sides of the board.
    • Remove the two screws on that are located on opposite sides of the board.
  7. Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
    • Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
Conclusão
Uma outra pessoa concluiu este guia.
Ross Light
Membro desde: 12-04-2010
175 Reputação
6 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,894
