Ir para o conteúdo principal
Magellan RoadMate 1200 Motherboard Replacement
O que você precisa
  1. Magellan RoadMate 1200 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Magellan RoadMate 1200 Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Motherboard Replacement: passo 3, imagem 1 %32 Magellan RoadMate 1200 Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Motherboard Replacement: passo 4, imagem 1 %32 Magellan RoadMate 1200 Motherboard Replacement: passo 4, imagem 2 %32
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
  5. Magellan RoadMate 1200 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove the two screws on that are located on opposite sides of the board.
  6. Magellan RoadMate 1200 Motherboard Replacement: passo 6, imagem 1 %32
    • Lift up the circuit board and disconnect the GPS wire, pulling horizontally from its connector port.
Conclusão
Uma outra pessoa concluiu este guia.
Ross Light
Membro desde: 04/12/10
217 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 5,010
