Introdução
A guide to accessing the RoadMate's display.
Ferramentas
Peças
Não são necessárias peças.
Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
Carefully flip the circuit board out so you can get to the sensor easily.
Remove the tape holding the sensor to the display and take out the sensor.
Undo the 4 clasps holding the display in place.
Pop the display from the front cover.
Uma outra pessoa concluiu este guia.
Um comentário
In order to remove the rubber plugs hiding the 4 screws, I found that a straight pin angled into the top of the plug can be used to lift them easily straight out and the plug is unharmed.
With the screws out, the back did not budge. I used the thinest blade screw driver in my jeweler's set to pry the case open and pushed on the plastic catches, one on each side that were holding it closed. They are visible in the photo of the back off.
