Ir para o conteúdo principal
Magellan RoadMate 1200 Back Cover Replacement
O que você precisa
  1. Magellan RoadMate 1200 Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Magellan RoadMate 1200 Back Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Back Cover Replacement: passo 2, imagem 1 %32
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Back Cover Replacement: passo 3, imagem 1 %32 Magellan RoadMate 1200 Back Cover Replacement: passo 3, imagem 2 %32
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Back Cover Replacement: passo 4, imagem 1 %32 Magellan RoadMate 1200 Back Cover Replacement: passo 4, imagem 2 %32
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
Conclusão
Ross Light
Membro desde: 04/12/10
217 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 3,467
