Ir para o conteúdo principal
Mad Catz Rock Band 4 Wireless Fender Whammy Bar Replacement
O que você precisa
  1. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement, Outer Casing: passo 1, imagem 1 %32
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: passo 2, imagem 1 %32
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: passo 3, imagem 1 %32
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement, Whammy Bar: passo 4, imagem 1 %32
    • Using a size J1 philips head screwdriver, remove the four black 5 mm screws (circled in red) from the cover on the whammy bar component.
  5. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: passo 5, imagem 1 %32
    • Using your hands, pull off the black cover and put the spring that pops out aside.
  6. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: passo 6, imagem 1 %32
    • Using your hands, pull out the rectangular circuit board from the whammy bar component.
  7. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: passo 7, imagem 1 %32
    • Follow the cord for the circuit board from the whammy bar, and using your hands pull it out of the main circuit board.
  8. Mad Catz Rock Band 4 Wireless Fender Whammy Bar  Replacement: passo 8, imagem 1 %32
    • Pull out the whammy bar.
Conclusão
Equipe
USF Tampa, Team 1-1, Cagle Fall 2016 Membro de USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,677
