Ir para o conteúdo principal
Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement
O que você precisa
  1. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement, Outer Casing: passo 1, imagem 1 %32
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement: passo 2, imagem 1 %32
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement: passo 3, imagem 1 %32
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement, Strum Bar: passo 4, imagem 1 %32
    • Using a size J1 head screwdriver, remove the six black 5 mm screws (circled in red) from the back of the strum button component.
  5. Mad Catz Rock Band 4 Wireless Fender Strum Bar Replacement: passo 5, imagem 1 %32
    • Lift out the circuit boards from above and below the strum component.
    • Unplug the circuit boards connected to the strum component from the main circuit board.
    • You should now be able to pull out the strum bar.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 1-1, Cagle Fall 2016 Membro de USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
Membros da 4
Autoria de 6 guias
Um comentário
Where can I fand a replacement part?
Logan Sturdivant - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 34
Duração total: 3,906
