Ir para o conteúdo principal
Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement
O que você precisa
  1. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement, Outer Casing: passo 1, imagem 1 %32
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: passo 2, imagem 1 %32
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: passo 3, imagem 1 %32
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement, Five Way Toggle Switch: passo 4, imagem 1 %32
    • Look for the toggle switch component on the inside of the guitar. The component rests in a black, circular holder that is positioned perpendicular relative to the inside of the front of the guitar.
    • Unscrew the two black, vertical, 5 mm philips head screws holding the part in place using a size J1 screwdriver.
  5. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: passo 5, imagem 1 %32
    • Pull the entire component out in a vertical motion.
  6. Mad Catz Rock Band 4 Wireless Fender 5 Way Toggle Switch Replacement: passo 6, imagem 1 %32
    • Follow the wires from the component to the main circuit board. Unplug the toggle switch component from the main board.
    • Plug in your replacement toggle switch hardware.
Conclusão
To reassemble your device, follow these instructions in reverse orde
Hollynn Ricker
Membro desde: 09/28/16
451 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-1, Cagle Fall 2016 Membro de USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 25
Duração total: 1,335
