Introdução
Needing a guide on how to fix a specific type of controller is very hard to come by nowadays. Luckily this guide can help you fix a damaged Mad Catz FightPad PRO controller joystick or customize your controller just for fun.
O que você precisa
Remove the single 6 mm screw on the back shell of the controller using a Phillips #00 screwdriver.
Using tweezers or your fingers, detach the wires connecting the motherboard to the rest of the controller.
Remove the eight 6 mm screws from the motherboard using a Phillips #00 screwdriver.
Uma outra pessoa concluiu este guia.
