Ir para o conteúdo principal
Mad Catz Dual Force 2 Pro Buttons Replacement
O que você precisa
  1. Mad Catz Dual Force 2 Pro Buttons Replacement, Buttons: passo 1, imagem 1 %32
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Buttons Replacement: passo 2, imagem 1 %32
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Buttons Replacement: passo 3, imagem 1 %32
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Buttons Replacement: passo 4, imagem 1 %32 Mad Catz Dual Force 2 Pro Buttons Replacement: passo 4, imagem 2 %32
    • Lift the closest circuit board away from the motherboard.
    • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
  5. Mad Catz Dual Force 2 Pro Buttons Replacement: passo 5, imagem 1 %32
    • Remove the two 7 mm Philip screws on the larger circuit board.
  6. Mad Catz Dual Force 2 Pro Buttons Replacement: passo 6, imagem 1 %32 Mad Catz Dual Force 2 Pro Buttons Replacement: passo 6, imagem 2 %32
    • Remove the motherboard assembly from the cover.
  7. Mad Catz Dual Force 2 Pro Buttons Replacement: passo 7, imagem 1 %32
    • Lift out any of the plastic buttons you want to replace.
Conclusão
Alexander Coyne
Membro desde: 01/11/15
658 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 7-2, Remmell Winter 2015 Membro de USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 532
