Ir para o conteúdo principal
Macintosh Powerbook 5300cs Hard Drive Replacement
O que você precisa
  1. Macintosh Powerbook 5300cs Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 2, imagem 1 %32
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs Hard Drive Replacement, Keyboard: passo 3, imagem 1 %32
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 4, imagem 1 %32 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 4, imagem 2 %32
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 5, imagem 1 %32 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 5, imagem 2 %32 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 5, imagem 3 %32
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  6. Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32 Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: passo 6, imagem 2 %32 Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: passo 6, imagem 3 %32
    • Remove the front plastic panel of the laptop by carefully lifting it up.
  7. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 7, imagem 1 %32
    • With a Torx #9 screwdriver, remove the three .30 in. screws that hold the metal frame in place.
  8. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 8, imagem 1 %32 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 8, imagem 2 %32 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 8, imagem 3 %32
    • Remove the metal chasis that holds the hard drive.
  9. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 9, imagem 1 %32
    • In order to remove the hard drive, remove the four .22 in. screws circled in red found on both sides of the metal chassis with a Torx #9 screwdriver.
  10. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 10, imagem 1 %32 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 10, imagem 2 %32
    • Pull the hard drive out.
Conclusão
Ronan
Membro desde: 10/10/11
63 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-1, Regan Fall 2011 Membro de Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 1,738
