Ir para o conteúdo principal
Macintosh Powerbook 5300cs Battery Replacement
O que você precisa
  1. Macintosh Powerbook 5300cs Battery Replacement, Battery: passo 1, imagem 1 %32
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Battery Replacement: passo 2, imagem 1 %32
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
    This is not to remove the battery, this is to remove the expansion slot (which has got the floppy disk module in it, in the first picture.
    blrutter - Responder
    Sorry I should have mentioned it in my prior comment. The battery has got a release button on it too, but it’s part of the battery, exposed on the front face of the right front corner when the battery is installed.
Conclusão
noah fischer
Membro desde: 10/10/11
222 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-1, Regan Fall 2011 Membro de Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
Membros da 4
Autoria de 6 guias
Um comentário
What’s the part number of the battery?
applerepairshop - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 1,544
